Page 5 of 26 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 256
  1. #41
    San Pedro Ca
    here i finished the body work on the fenders and primed them , i also built one bunk wrapped it in carpet used all stainless steel , carriage bolts, staples too Name:  IMG_5338.jpg
Size:  78.8 KBName:  IMG_5339.jpg
Size:  50.2 KBName:  IMG_5340.jpg
Size:  78.0 KBName:  IMG_5341.jpg
Size:  72.6 KBName:  IMG_5342.jpg
Size:  49.4 KBName:  IMG_5343.jpg
Size:  57.3 KBName:  IMG_5344.jpg
Size:  57.9 KBName:  IMG_5345.jpg
Size:  74.0 KBName:  IMG_5346.jpg
  2. #42
    Jan 2013
    That looks like A LOT of work!!! It's looking good!
    www.nickroseinsurance.com
    CA: 661.253.1131
    AZ: 928-669-2900
  3. #43
    San Pedro Ca
    Quote Originally Posted by hbchgirl View Post
    [B]its a crazy amount of work lol should of sent it out lol
  4. #44
    San Pedro Ca
    finished the other bunk today , bad weather not much else got done, mess got cleaned up for the rain tonight Name:  IMG_5347.jpg
Size:  89.3 KBName:  IMG_5348.jpg
Size:  82.6 KB and also got the mount for the draw bar mounted today no draw bar yet waiting on paint Name:  IMG_5349.jpg
Size:  113.7 KBalso made this little cable for the draw bar pin , if you drop it , its right there!! no more lost pinsName:  IMG_5350.jpg
Size:  54.0 KBName:  IMG_5351.jpg
  5. #45
    Dec 2012
    SoCal- Fontana
    What are the spacers for? Is that the way it was or did you want the boat so sit higher?
  6. #46
    San Pedro Ca
    since the bunks are longer than the flat part of the hull the bunks bend down in the midgle and once the weight is on them it sits nice and cozy front to rear
  7. #47
    San Pedro Ca
    or better explanation the bottom of the hull is kind of banana shaped so when the center almost touches the frame both ends are frim on the bottom of the hull right below the stringers, i had to move them a few inches to get them under the stringers where they should be
  8. #48
    Looking good. Spray paint?
  9. #49
    San Pedro Ca
    mo its valspar low voc single stage shot out of a Iwata HVLP gun with a 1.3 mm tip and 35 pounds of air pressure in my back yard with calm winds lol
  10. #50
    San Pedro Ca
    break in the weather got the bottom side of the fenders painted Name:  IMG_5353.jpg
Size:  86.0 KBName:  IMG_5354.jpg
Size:  78.6 KBName:  IMG_5355.jpg
Size:  83.4 KBalso mounted the draw bar pin retaining cable and put a pad where the draw bar sits when not attached Name:  IMG_5357.jpg
Size:  64.7 KBName:  IMG_5356.jpg
