 Originally Posted by SBS933
If you take out a contract on all your appliances you will be as good as gold. I have never had any luck with the lid switch, everyone else does. I only had luck with the defrost timer once on my fridge. Other than that it was always back to the appliance store.
My beer fridge is out too. :(
Sounds like you over revved it and threw a rod.. Better pull the pan and get back to us
Now THAT is serious... You can take your dirty clothes down to the creek and beat them on a rock/wash them... But warm beer??? BLECH!!!!!
The last time mine wouldnt spin it was the small plastic/rubber/plastic "lovejoy" coupling that came apart... It's a blur now but I know that was the broken part... Seems like it would wash/agitate but not spin/extract...
Yea, the video I watched was making the same noise mine has and they replaced the flex coupling. Looks easy to fix.
some small spring clips are all that holds the MFing motor to the frame BUT if you dont get the plastic halves all the way onto the motor shaft you wont ever get the spring clips to latch... I was shy by about 1/16" of having the plastic part all the way on the motor shaft and it wouldn't latch back together, I used a deep socket as a drift to tap it the rest of the way on so that I didn't crack the little drive dogs on the coupler... It's coming back to me now...
Also, if the coupler halves arent all the way in place it will load the armature to the opposite end of the motor housing/bearings and it will drag, make sure it spins freely by and after you get it back together and your golden...
The real punishment would be going to a laundromat to wash clothes. :(
some small spring clips are all that holds the MFing motor to the frame BUT if you dont get the plastic halves all the way onto the motor shaft you wont ever get the spring clips to latch... It's coming back to me now...
Yea, I saw those in video. Thanks!
Ugh, i think i would toss the dirty clothes and buy new before I went to that extreme...
Excuse me gentlemen.
VIC! Can you please move this nonsense to the tech forum, or put it with the gizmo that makes smoothies and protein drinks.
Thank you
VIC! Can you please move this nonsense to the tech forum. Thank you!
There's a tech section?
