Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Prop help
    Kalifornia
    Prop help
    I dinged up my good prop a couple weeks ago (yeah I know).... Now I need to get it fixed. I had Cutting Edge do some work to it 2 years ago. Cut most of the diffuser off, and tweaked it. I told him I wanted a couple hundred more RPM's and it gave me about 100... I'm guessing.
    The prop is a 28 Mach, which they apparently don't make any more. The boat has always run wet, I can't trim it enough to get the Bow out of the water
    I'm thinking I want the rest of the diffuser cut off at least.. Thoughts?
    A couple shots that 2FF took this weekend
    Prop help
    The last pic has it carrying a little bow.
    I'm sure you tried Bravo 1's? If not it should be easy to borrow some.
    Kalifornia
    I have a 26 Bravo for it.. It hates it. Buries the nose, and is 5 or 6 MPH slower, and blows out when planning. I keep it for an emergency spare.
    Member Patyacht's Avatar
    Desert Hill, AZ
    Go see JJ Gibbs in Havasu of Gibbs Props.
    http://thereasariordan.webs.com/Indexgibbs.html
    Pat
    F-29 DCB
    wanna try my 5 blade ...
    also you can try my solas 26... I only turn it 4600...and you seen how fast....
    Kalifornia
    Prop help
    5 blade what?
    5 blade what?
    its a ron hill prop...I didn't have enough power to turn it...26p 5 blade...
    Unforgiven
    I have the power..let me try it...
    Prop help
    Is you hull stepped? Grab a 28p Maximus w a 15 1/4" dia.
    It made a huge difference on my straight bottom 270. I'll post the thread I started on another site.
