it has the rpm air gap,... I went on line and holley recommends this carb for my motor
the carb has had some guru's in it so I want ed to get a base ...
holley sent it out with pri jets ...78 (part # not drill) and 82 sec... also the power valves are 4.5 pri....3.5 sec..
I know you like to pull the sec power valve and I will probley do that next go round
That's what the book says it should have...
correct..
Re: Who here know holley carbs...
Will bad Penny's wheels bolt up? Interested to see how that combo would look on the 72
Sent from my DROID RAZR HD using Tapatalk 2
Ditch the 850 vac secondary and put a 4150 on there.
And send Brain you fuel bills.
lol....i'm keeping the vac secondarys
what do you think the vac. should be at,... and 32 degrees timing sound good?
