 Originally Posted by WMC
Player you just sold me. Thanks
just help'n out a little...
 Originally Posted by cab_01
Good info. I am getting ready to rebuild a 76 350 and put it in my 65 c-10 I am restoring. I usually run sta-bil in my desert toys and motor home. Do you think Lucas is a good product and should I run it in the truck?
Depends on how much you build the motor. I was told by a carb guy in Upland that does ALOT of high performance stuff not to use Sta bil in hi perf builds because it lowers octane numbers.
lets see your hallett....
Sweet C10!
thanks, I've had it forever....tried to give it away...
I restored the truck 20 yrs ago.... then used it as a truck...
we used to tow the 272 Baja to mead with it
super rare super Cheyenne, fac big block truck, power disc, tilt, tach dash, leaf spring 12 bolt posi, built turbo 400 2500 stall.
power windows...
I agree here, lucas is the only way to go..that and fresh fuel..
You would have seen it last Saturday at the Springs breakfast run if the weather had not gone to shit. I can't post pics on here from my phone. I'll try later from home.
turned out to be hella nice out
Not going to put Sta Bil in the truck. The only reason i put it in the motor home is so that it gets into the generator. I will use the Lucas in the truck.
Oh and it will be a mild build. I am restoring this truck with my son. He is 16 and when he goes to college I am going to give it to him. He doesn't know that part yet.
Why you should put lucas upper cylinder lubricant
For generators and stuff that might sit for a while. Use this in the gas that will sit.
When you put fresh gas in use upper cylinder lube.
