03-20-2014, 12:22 PM
#151
 Originally Posted by Mitch
Hmm ? I was serious a quick disconnect band style clamp is the bad ass way to hang that .Pull one lever and its off no fuckin around . FYI look at Neil and Parks web site check out the tri drive and how the accessories are mounted I think you will enjoy checking it out it bad ass like your stuff .
I am getting one of these for my Dad's deck boat.
03-20-2014, 04:20 PM
#152
Are you talking about a V-band clamp?
Yes v band quick disconect ran them on my comp eliminator simple clean bullet proof , perfect alingment and no fastners .What I liked is if you wanted to service lets say the side just pull the lever half way and rotate it up and lock it back down .
03-20-2014, 04:29 PM
#153
![Name: towelrack[1].jpg
Size: 20.9 KB](http://www.hotboat.com/frm/attachment.php?attachmentid=36375&d=1395343341)
Why not use it for a step on the back of your boat
03-22-2014, 08:05 PM
#154
Cam drive for the pump. Shaft socket is .750 major, .500 minor triangulated full radius profile made from 15-5PH h950 condition. Should be plenty strong.
03-22-2014, 08:09 PM
#155
Nice setup! I like it
03-22-2014, 09:55 PM
#156
Very nice
03-22-2014, 10:02 PM
#157
The drive spud is shaped to match that, instead of a regular hex?
03-22-2014, 10:05 PM
#158
Yes. It's on the machine I'll put up pics in a little while.
03-22-2014, 11:11 PM
#159
Okay, here you go. The drive end of the shaft to mate with the cam drive. Shaft is made from A-286, all diameters ended being .0007 total run-out. It has 2 large bearings in the center of the shaft with a .0003 press so they won't be too hard to get off if they ever need replacing. I gave it .005 clearance on the male to female fit of the drive end to allow for any misalignment when it all goes together.
03-23-2014, 11:57 AM
#160
