 Originally Posted by WOTM
Was the oil injection system removed or has it always been a premix motor? If not it would be a temperature sender. Was it a solid horn or been beeb beeb?
Hmm...from first glance I think it's always been a premix motor. It's always been a beep.....beep......never a solid horn.
Here's the only picture I have of it at the moment....not sure if it helps.
Sent from my Kyocera.
You have bigger problems than just the alarm. It looks like your whole world has gone sideways.
Its the new Pacific Intercoastal Vertical Waterway. Its a bitch to get on, but once you're on its a helluva ride
Typically a pulsing beeb is low oil level. But that does not mix with it being a premixed motor. What does the wiring harness look like any bare wire? Chaffing or corrosion evidence?
Is there any consistency when the horn sounds, like only after long periods if idling or cursing speeds.
Could be as simple as a bad horn or sender
Has the impeller and thermostat been replaced recently?
If nothing else call the shop tomorrow and I'll get you covered!
Thanks!
I will check out the harness and see what it looks like. The horn seems to only be there when idling in the harbor. If I turn the key to a certain spot it will go off....?
The guy I picked the boat up from said he just tuned up the motor but you know how that goes.
 Originally Posted by menace marine
you have bigger problems than just the alarm. It looks like your whole world has gone sideways.
Sent from my iphone using tapatalk
lol...
Hmm...I guess this was an oil injected motor. That is what the VRO stands for?
Variable ratio Oil
