03-06-2014, 07:54 PM
#281
 Originally Posted by Mitch
The boat in your avatar looks a little wet what does it run about 50 ? tell me about your prop
Yes, tell us about your Stoker.
Sent using Tapatalk.
03-06-2014, 08:02 PM
#282
Ok I got a few things for you and Marc to look at as well as some sketches. Im going to move my exhaust ports to the center and need a flush bezel for starters .
I'm thinking about doing the same thing. Might look a little funny on a blown deal though.
Marc's going to be there, you can give him the sketches if you want.
03-06-2014, 08:03 PM
#283
The only Schiada I ever had that ran 50 was only 10' long
It runs 81MPH on the GPS in perfect conditions, lightly loaded running a 26P 4 blade cleaver (Labbed) .....here's a video running high 70's with full fuel
03-06-2014, 08:05 PM
#284
Paul, is your boat a tunnel?
#285
It would look BadbAss Imco made me a template all i got to do is find it
03-06-2014, 08:08 PM
#286
[QUOTE=Paul65K;98004]The only Schiada I ever had that ran 50 was only 10' long
It runs 81MPH on the GPS in perfect conditions, lightly loaded running a 26P 4 blade cleaver (Labbed) .....here's a video running high 70's with full fuel :
I was wondering if it was a Hill signature if its a cleaver probably not, you keep drinking that cool aide my friend .....
#287
Yes it is.....21RT with a setback motor mount......won't run with a Stoker as it's probably a good 500 - 800lbs heavier, but I'm guessing that I probably will be more comfortable in the chop.
I'm running a TorqueMaster lower so probably a couple of mph there but not really interested in going much faster personally
03-06-2014, 08:09 PM
#288
[QUOTE=Mitch;98007]
Kool-aid.....then I must have a defective GPS speedo......do you think I should return it
03-06-2014, 08:15 PM
#289
03-06-2014, 08:17 PM
#290
Oops....forgot the video......here we go
