Page 7 of 26 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 256
  1. #61
    San Pedro Ca
    We're dedicated server, no way you can bog this boat down
    whats the best way to upload using a mac than? its the upload time .. and aim on a t3 line by myself its fast except for uploading here? what am i doing wrong?
  2. #62
    I'll check with GH. I did almost 90 fairly high res files, each 30 was around 25M, in less than 6-7min on cable.
  3. #63
    I have no issues uploading from my Mac. Are you uploading pictures directly off your computer?
    When you go to upload pictures are you clicking 'manage attachments' ?
  4. #64
    San Pedro Ca
    no i click the photo box in the thread than it opens a box where i can use url or select files, i select files my computer go to my photos open photos click and hold the command key add selected photos than it starts the upload
  5. #65
    San Pedro Ca
Size:  72.7 KBName:  IMG_5380.jpg
Size:  79.0 KB top side of fenders i block sanded the first coat of primer i knew i had minor spots bad weather anyways than i filled all the imperfections and primed the top again , needs to be blocked out and painted ..
  6. #66
    San Pedro Ca
    Looks the same as it before i started except its smooth i missed a few i found so itll have color in the next pictures, also i sprayed rubberizedundercoating under the fenders , why because i had itName:  IMG_5381.jpg
Size:  88.8 KBName:  IMG_5382.jpg
Size:  75.8 KBName:  IMG_5383.jpg
Size:  70.1 KBName:  IMG_5384.jpg
Size:  60.4 KBName:  IMG_5385.jpg
Size:  27.6 KBName:  IMG_5386.jpg
  7. #67
    San Pedro Ca
    blocked with 600 grit than a coat of color its ready for reassembly in a day or two let the paint cure up good Name:  IMG_5389.jpg
Size:  69.3 KBName:  IMG_5390.jpg
Size:  84.5 KBName:  IMG_5391.jpg
Size:  70.1 KBName:  IMG_5392.jpg
Size:  68.9 KBName:  IMG_5393.jpg
  8. #68
    One stage or two?? Looks good.
  9. #69
    San Pedro Ca
    Valspar single stage
  10. #70
    San Pedro Ca
    some wiring done and the housing for the light fitted but not tight paint still tackyName:  IMG_5395.jpg
Size:  146.0 KBName:  IMG_5396.jpg
Size:  90.6 KBName:  IMG_5397.jpg
