02-03-2014, 06:13 PM
#171
All right, I'm going to put this out there again but I'm not going into longwinded detail again.
AQ17 is the same as 17-4PH (H1150 condition)..............................135,000 PSI tensile, 105,000 tension, 70,000 torsion
AQ22 is Nitronic 50 With a slightly different H/T process..................145,000 PSI tensile, 130,000 tension, 86,000 torsion
K Monel is nickel 500 or K500.............................................. ........145,000 PSI tensile, 110,000 tension
These materials are all subject to work hardening if not machined correctly. They can get micro stress cracks and fail.
02-03-2014, 07:00 PM
#172
Both the machining of the key way and well as the taper. Specially if the spindle speed at the large end of the taper is too fast for the diameter.
I am still suspect that were seen at the enduro may have been the result of machining,
02-03-2014, 07:04 PM
#173
i went to the company you had mentioned and i had them picked as my supplier if i got a new one now its confirmed thanks for the help
02-03-2014, 07:16 PM
#174
Constant surface foot.
02-03-2014, 07:41 PM
#175
Well that should prove to be a trick in itself right there. Good luck with that.
would you care to elaborate ?
02-03-2014, 07:45 PM
#176
He's talking about magnetic properties of stainless. However 17-4 is magnetic.
02-03-2014, 08:00 PM
#177
It is, but I have never had very good luck magging it.
I also find it interesting he is feeding a blown BB Mopar thru a 1" AQ 17 shaft.
02-03-2014, 08:03 PM
#178
I think it's the shaft that was in it when he got it.
02-03-2014, 08:07 PM
#179
Are you one of these guys OG?
02-03-2014, 08:12 PM
#180
its whats in the boat when i bought it, i am asking what to use for the boat, why can't you just help without your bs ????????? when i bought the boat it had a bone stock 440 with a tunnel ram that wouldn't run it was all wrong i built the blower motor and this is what i have now, so either lend a hand or educate or just be quiet please its very annoying
