02-03-2014, 03:01 PM
#131
 Originally Posted by MrDenton
Can I add some boating content here?
AQ22, AQ22HS, AQ19, AQ17 and K500. What are the differences, how can I tell what,if any if those, I might have. As some know, I own the former SS/PS8 Mango Madness. I bought it from Darner less engine and trailer. Just curious what I might have/need.
I'm planning on sending the rudder, props and shaft out for X-ray. Any suggestions on where to send them in the SoCal/Corona area?
Blown Gas Flats to Rope...
In loving memory of
Chris "Church Mouse" Blevens
first, I would asked Darner what is in the boat.
Second, yes slight color difference between Monel and some Aquamets and 316. Hard to explain how you tell over the internet.
Maybe Westernaero can help, he works with exotic alloys for a living.
Not sure its necessary to have your stuff X rayed. Wet mag will usually tell you what you need to know, unless some of it is stainless.
X ray is great for looking for inclusions when it was forged or welded. I don't think you are looking for that are you.
Cracks tend to form on the surface first, and wet magging will detect those pretty well. Reading X rays can be a art form, and its not a whole lot easier to see a hairline crack in X ray than on the object itself.
02-03-2014, 03:08 PM
#132
Wet mag? At Irvine last year I watched a TFH team member spraying stuff on the props then some other stuff. Said he was looking for cracks.
Yes Bob, cracks are what I'm looking for.
In loving memory of
02-03-2014, 03:14 PM
#133
500 will be slightly darker/grey than AQ22. Unless you have the 2 material right next to each other you won't be able to tell.
K500 on the left, 2507 Duplex(very close to AQ22) on the right.
02-03-2014, 03:18 PM
#134
Threads or posts that get bad comments are not removed simply because they got bad comments. I'm not saying yours did, I can't even find the thread. So again, I'm not sure what you're talking about.
it was removed lol that why you can't find it lol
02-03-2014, 03:20 PM
#135
In loving memory of
greg i had a race team with there equipment check mine for but i do trust Gary at wimington propeller may want to call him buddy
02-03-2014, 03:21 PM
#136
Denton, you might put a magnet to the shaft first. If it's lightly magnetic then it's most likely AQ17(17-4PH H1150).
#137
Can't afford an inch. I'll contact Darner. Thanks.
In loving memory of
there ARE LOCAL SHOPS THAT HAVE A DYE LIQUID THEY APPLY AND IT TELLS THEM EXACTLY WHAT IT IS..
02-03-2014, 03:24 PM
#138
In loving memory of
its a two part dye one soaks in the other brings out the crack
02-03-2014, 03:26 PM
#139
In loving memory of
We use crack detector on our prop, mainly because it stainless and can't be mag'd. Its great for in the field use, like a fuel hydro between rounds. You can get at Granger or Mc Master Carr.
That is not wet mag. Wet mag involves magnetizing the part and magnetic dust in a solution that the part is either dip in or it is sprayed on an the particles will adhere to the crack due to north/south at the crack, and are detectable under a black light. Dry mag is similar except it is dry power and it leave a white line that can harder to see if the crack is very short and thin.
02-03-2014, 03:30 PM
#140
just got off the phone with the girl at rewarder headers she says the only difference between the long jet boat headers and the v drive headers are the water lines .. so what can you say about that ???
