454 BBC parts
4 bolt block, .030" over(1973), forged 7416 crankshaft, 7/16 rods with .030" pistons and a GM 454 damper $550 Block has one sleeve. Crank is rusty from sitting and will need to be turned.
4 bolt block (1977)that is currently at .030 and needs a sleeve installed $250
4 bolt block at .060" with a sleeve $250 (didn't pull this one out to check date)
4 bolt block at .060" (1977) no sleeves $300
4 bolt Gen 6 blocks std bore $400 each
Gen 6 502/454 forged crank std $350
Gen 6 427 crank $250
7416 forged GM 454 crank, looks good to go at .010/.010 $300
I also have a bunch of misc GM BBC cylinder heads, including quite a few 990 castings, as well as a couple of Merlin iron heads. I prefer someone inspect the 990's and Merlins in person if they plan to buy a single to match an existing head.
All parts located in Southern California easy access from the 210 and 57 freeway
Barry - You have a 502 GEN 6 bolt that will run at standard? Thanks Tom
No, sorry, 502 blocks are hard to come by, none here.
