 Originally Posted by Cat & Mice
What you are missing here is the wind speed. There is a huge headwind that is helping the plane take off. Listen to how loud the wind noise is. In fact you could argue that the treadmill would create enough wind at high speeds to do exactly what this plane is doing in this video.
Just like before the responses to this thread truelly baffles me.
I think you actually believe it will fly and you are just stirring the pot.
MP
First you cant tell from the video which way the wind is coming from. Second, that plane is from Alaska, and is built specifically to take off in one foot like that. In fact, there is actually a competition for pilots to build and take off in planes that have been customized to be able to take off in the shortest distance possible. That plane is one of them. The wind might be an issue, but how much is hard to tell....
Actually, I don't believe the plane, as posed in the question, a 747 will fly, but this one would.
 Originally Posted by Tishimself
Oh, oh wow. LOL. That was mind boggling, to say the least. I'll have whatever he's having. LOL. The treadmill is a non issue. All it needs to do is be large enough and long enough and fast enough to fulfill the requirements of the question. The friction is between the wheels of the plane and the surface of the treadmill. If anything, you need bearings on all those wheels that can withstand the stress. Again, all you need to know is this. It's all about the speed of the wheels. period. YOu get caught up in all the other BS and that's your downfall. The wheels transmit the thrust into movement. as long as the treadmill is moving in the OPPOSITE direction the plane is traveling, and the treadmill and wheels are moving at the same speed but in opposite directions, the plane will not move. Deal with it. YOu have overthought this way too far. It's actually very simple.
With one caveat. the original question ONLY posed the problem using a 747. There are other types of planes that will fly. The 747 and other types of aircraft will not.
Can a man pull one of your train cars with his teeth if the track is level? If so how can this be, the train weighs TONS...
Maybe he has great teeth?? Maybe he uses polydent? No idea.
Myself and one other person moved 2, 35,000 lb chillers on a gantry crane 50 60 ft at the Glen Canyon dam a few years back. Hardest part was stopping them, not moving them.
Lets take Tish's imaginary plane and change it up a little. Lets hang it from a continuous beam, on a cable to a beam trolley. Now any 5 year old can move the plane on the beam. Easy. Now start moving the beam, as fast as you care to. All the planes prop has to do, is over come the friction of the beam trolley to reamin still. Its not much. To move forward, it only has to produce more THRUST than it takes to hold it still while the beam moves.
The "effort" the plane needs to put up to remain still while the beam moves is so low, it could be held in position by one person with a rope. Its only the friction put up by the trolley wheels, which very little. If you can move the plane, you can hold the plane.
You see, Tish wants ALL the thrust to equal ALL the friction, and thats fanatasy. Its bench racing at its finest.
He isn't applying any real physics to his mind game, just what he sees in his mind. It seems plausible to him, therefore, it is.
All he has to do is overcome the rolling resistance of the train, with steel on steel its not much assuming the track is level... true???
thrust is thrust is thrust... as soon as the brakes on the aero-plane are UNlocked and the JET thrust starts to build OR the prop spins up and thrust builds up, the backward speed of the plane will slow and it will come to a stop when the thrust is greater enough to overcome the rolling resistance of the pneumatic tires on the conveyor belt/friction of the bearings from the weight of the plane... Any additional thrust will put him in forward motion...
Fpr what it's worth, a train wheel, any train wheel, sits on top of the railhead on a spot the size of a dime. Eight dimes is all the friction you get. No more, no less. Like I said, there are literally thousands upon thousands of pages of people battling out this question going back to the beginning of the 90's...no one side ever gives in, no one ever gets the other guys point. Personally, I could care less. This thread proves that the same things that made the thread on the first HB so virulent are still here. It was fun, but I'm out. You guys take it from here.....<B>
SO, a guy can apply 100lbs of force and overcome the friction created by the 58,000 lbs train car, doesn't it stand to reason that a jet engine with enough thrust to lift as much weight or more 60'000 feet into the air, it can overcome the "rolling resistence" of the weight of the aero-plane on the bearings/tires EVEN if it has to overcome the friction of an extra 800MPH of surface footage/bearing speed??? Once the plane has THRUSTED itself to a stop with minimal thrust it is CLEARED FOR TAKEOFF...
It doesn't get settled because the "it can't fly" crowd what to come up with bullshit that keeps it grounded. No real physics, just new rules that say the friction equals the thrust. PROVE IT!
Like I said, its bench racing at its finest. Ever bench race? Ever win? Those that always claim to win bench races are those that have never actually raced. ANYTHING! EVER! Those are the hardest to beat.
Once upon a time brother, I argued on the other site just because I liked to argue. I didn't care what the topic was, as long as it was a heated lively discussion. And I got a lot of folks mad at me, and I got banned from that other site. When I was getting ready to post this up, I knew it had the potential to be as harsh a thread as it once was, but there was just enough doubt that I posted it up anyways. Now, I find that the back and forth bores me to no end. Call it getting older, I don't know. But I know there are far more interesting and entertaining things to talk about than planes and treadmills. I gotta go find something, anything else to talk about, or finish up some work on this car I am building for the layout......
hey, that reminds me. Where about do you live, and how are you with LGB stuff.
I need help with controlling a track layout.
