 Originally Posted by Tishimself
OK. lets get it straight here. Here is the way it works. Take the plane, set it on the treadmill. turn on the treadmill, spin it up so that the wheels on the plane are turning, just as if it is taxiing. AS you increase the power on the jet engines, the speed of the treadmill increases also. AS time goes by, the treadmill is spinning the wheels at 300+mph. Maybe faster. This counters the wheels ability to turn thrust into movement through the wheels. IF the plane can not move forward, it can not generate lift across the flight surfaces of the wing. Hard as the engines "screw" themselves through the air, they cannot overcome the negative forces generated by the treadmill turning in the opposite direction. Which brings in law of physics which states that "For ever action there is an equal and opposite reaction". This argument was always limited to jet powered aircraft, as a plane with the prop in the nose generate airflow over the wing surfaces through prop wash. Same with planes with engines on the wings. Such as a King Air. (my favorite plane). But for aircraft with an engine under the wing, with thrust generated after the wing surfaces, ( a jet) there is no source for air over the flight surfaces, because no movement can be generated because the wheels have no ability to roll the aircraft forfard. Remember, as the aircraft moves, the speed of the treadmill increases till the speed returns to a zero indicator. Got it?
Did you read what you wrote here. You want to take another shot that? That's hilarious.
And what asshole did you pull this out of? You must of heard this on Big Bang Theory, Right?
Aircraft (prop or jet) generate thrust. They pull themselves through air. Bernoulli's principal and the wing allows them to fly.
The speed the wheels are turning or the direction they're turning is irrelevant.
Why? Why do you say the treadmills is spinning the wheels faster and faster?
Lets start with some "ground" rules, what is the FIXED speed of your treadmill? Tishimself, lets make it interesting:
The treadmill is ONE MILE LONG, fixed speed of 6MPH (ten minute mile)
The engines on the aero-plane are NOT running
There is a cliff at both ends that drops to the abyss and the plane is sitting at the FAR end and has one mile / ten minutes to throttle UP and get airborn...
OR else...
Press GO and the airplane is now moving in reverse at 6MPH...
Now what???
Well, lets look at it from a different direction. Lets look at the landing gear as being the same as roller skates on your feet. If your on a treadmill with skates on, the only way you can move forward is by holding onto a stationary object. I.E. and handle bar, or a rope. Otherwise, you might roll back, actually. That's what the air is for the plane. It's a rope or stationary object that it grabs onto and pulls itself forward, unlike the tires on a car for instance. Which lets it move forward regardless of wheel speed. Right? Sorta. As you move forward, the treadmill speed increases, meaning you have to work harder to keep moving forward due to increased friction between the wheels of your skates and the treadmill. As the speeds increase, so does the strength needed to pull yourself forward. Sooner or later, it's just too much work, and you stop moving forward. This is the same with the plane, it can only pull forward so hard, and then that's it. Same here. Everyone concentrates on the wheels, and not the forces themselves at work here. The wheels are only the instrument with which the engines transmit thrust into movement. They are not powered.
 Originally Posted by Ziggy
Those pics should stay in the long lost files, honestly. Not something that would be productive today.....but the memories will be lasting til alzheimer sets in.
God bless the Canatard
From my POS T-mobile thingie
I have to agree with Ziggy! those that were let into the Box were trusted not to re-post the pixs anywhere else, and great memories is an under statement, but I would have to admit I wouldn't mind seeing them one more time!
OR else...
Now what???
The fallacy of your logic (as I see it at least), is that you're forgetting something. The wheels of the airplane are connected to the plane, and friction exists between the runway (conveyor belt) and the wheels.
For the plane to take off, it has to reach a certain airspeed - the speed at which the air passing over the wing is enough to create lift. In order for the plane, which is on the ground, to reach a forward speed, its wheels would need to be travelling in a net forward direction. In order for this to happen, their speed would have to be GREATER than that of the belt running beneath them.
If, as the above indicates, the speeds are ALWAYS equal, then the plane will not move.
DO you agree with the framework OR do you want to pick a speed?
There is no set speed. They (no matter the number) should always be equal.
Now STFU!
Says it right there in the video. Wheel speed has nothing to do with air speed.
