4.4 or 4.5 on a 427 block??? Sounds like we had better call L.A. Sleeve...
Hey Einstein, break out your trusty highly tuned slide rule and tell be how you got those numbers from a .017/.027 or even a .020/,030 over bore with a 427 block?
Hey Bob, isn't it the early 390 blocks (and other early F.E.'s) and only the ones not affected by core shift that can take the 427 bore?
Here Bob, I will give you the factory tolerance list and let you figga it all out...
427 block "cylinder grade D" upper tolerance limit is 4.2364" diameter. This is a standard 427 bore, the tolerance range of which goes from 4.2328" to 4.2364". From 1958 through about 1967 there were 12 cylinder bore grade steps (12345678ABCD) of .0003" each, and from about 1968 through 1978 there were nine cylinder bore grade steps (123456ABC) with .0004" increments. I believe the number of steps was decreased because newer pistons used better thermal expansion technology.
GUY IN AZ DIDNT PICK IT UP SO THE GUY CALLED THIS MORN...my guy just picked it up... it was originaly built for the owner of laveycraft same owner 30 yrs,,, i sold the motor already less marine hardware for $1500 ...AND I NEVER LEFT THE HOUSE !!!!!!! the guy who picked it up wanted the motor,,i worked this dealio for days just in case the guy didnt pick it up from az
has a casale split cASE also nice finishline hardware i will be parting out the rest..let me know if you want anything off it...she will BE parted out over the weekend.....
one boat must die so a few more can live.....................MY NEW YRS RESO..........
So, is the hull in good shape?
whats your email (pm me)and i will send u detailed pics before its stripped
Needs to be your sig.
i may just do that................
No Ford FE block can be bored to 4.23 except 427 blocks, regardless of core shift.
Some, and very very few, 390s can be bore safely to 4.130 (406 and 428), and none of them are pre 1963 390s. There are the yahoos that say you can, but they are making any real power with them. Even then, the pistons have to be custom made. there are NO shelf stock 4.130 pistons anymore. Rings are priced like gold, with a VERY small selection.
Take the largest factory tolerance and add it to a the largest over bore I posted, and come up with a 4.4 or 4.5 bore,
Put up the numbers Bruce, or turn in your Ford lover's hat and STFU
1500 for a 390 without the marine gear. That is either the dumbest man alive, or that isn't a 390. In which case he stole the engine.
he said something about the manifold is from a 427 so its the good fe motor and he was stoked to get it..
