 Originally Posted by McRib
My guess is pemex may have a higher sulfur count and less detergents in it.
Sent from my SGH-M919 using Tapatalk
My guess is it is not what they putting in, but what they aren't removing, and what the actual chemistry is in their blend.
Gasoline isn't just one compound, its dozens. The gasoline in the US, and particularly Cal and NY, and some other major cities in the country is a completely different formulation than other parts. But all gas in the US is what they call "reformulated gasoline". If you sold this stuff in 60s and 70s, you would go to jail because it doesn't come near the definition of gasoline as described by the feds back then.
When cat converters first arrived, the smell from cars was disgusting. When the sulfer in the fuel hits the converter, along with any unburnt hydrocarbons, the heat in the convertor makes it form hydrogen sulfide. Rotten eggs.
My guess is that Premex doesn't go thru the process to eliminate the sulfer in the fuel and that's what you are smelling.
Way above my pay grade buddy. Lol. I just put the shit in my car. Lol
If you drove a car in the mid 70s when converters first came out, you'd know that smell very well.
But like I said, its not what they are putting in, its what they aren't removing.
You hang around a refinery and you see tanker trucks hauling molten sulfer out about once an hour. Don't ask where they are taking it, I have no clue. I just know between the diesel and the gasoline, they are removing one shit load of sulfer every day.
There is a place down in the LA ports that sells sulfur in powder form...yellow shit stank to high hell...they did nothing to even try to cover it....it smells like rotten eggs, and worse....
A lot of that is headed over seas for steel production. Huge piles of coke from the refineries down there for the same reason. But it doesn't smell.
Yeah, but the rail doesn't go by those...it goes right by the sulfur company, and I almost always got stopped next to it. If I didn't there is a rail crossing close by and the speed restriction over it was 10mph..either way...it was gross.....
I dont know if it is still the case but I recall hearing that there WERE over 40 formulas in the U.S.... Nearly every state had their own formula and by law could not use supplies from other states that dont meet the spec...
I dont know if it got WORSE or better since the time I heard that statistic..
All Missouri gas is 10% alcohol minimum... Plus who knows what else...
Maybe I could bottle the smell and call it Grads.
Bench race driver of the NHRA 16X Castrol GTX Mustang
Note to self: Never ask GN7 what time it is unless you want a 20 minute dissertation on the differentiation between what we call the time of day and the relative variation to the world atomic clock
Only kidding dude.....no offense meant
Most land locked GM motors have that same smell
The Fords are broken down so no fumes are released.
