Just a heads up, if you are using Photoshop to add the HB watermark, look into using the "automate batch" feature. You can set it up to open images, add watermark, change transparency of watermark, resize the image and save to a the, or a different, folder. You can run it and walk away. No need to manually insert the watermark. Of course, there might be a few you will have to do manually because of where the watermark will be placed, but overall it will save a ton of time.
I've been using Lightroom, it works great. Not sure what he's using, but Lightroom is the way to go IMO
I know how to use the batch to add the watermark but the problem is I generally like to "touch" up each picture or crop it. I haven't really figured out how to auto "touch up" and crop then watermark.
Edit: using PS
Edit: using PS
The Mac should have Lightroom. You can edit each pic before you batch export and watermark. It also does all sorts of other things to catalog your albums. It really is way better and handling what we do vs Photshop.
Edit: using PS
If you are editing the photos by adding saturation, the can also be automated, unless you are doing each picture by eye. Cropping would be a different story as you are not cropping them all in the same spot.
You can also make different "actions", to where you can apply the action to each picture as it is open. Another time saver.
BTW, nice pictures!
