Should be a easy removal and drop in. I have done several. Just don't forget about the trim switch wires before you start yanking.
Are you changing just because it shifts hard or changing just to change?
Good question.
Good question. Chances are if its hard to shift changing shifters won't fix it. If it is awkward that's a different story. As far as the install it is very straightforward. If you have any questions along the way feel free to give me a call. I can talk you through it.
Dustin
661-755-0620
Dustin
661-755-0620
sent from WMC's phone
There's no issue with it, it's just that the Livorsi shifts so much more smoothly. Plus they look much better IMO. Probably more costly then I really need, just wanted to do something on the boat this off season.
Dustin
661-755-0620
Very cool offer Dustin. Thanks!
 Originally Posted by Music to my Ears
Thanks for all of the input guys. Very helpful!
It was real easy..but I do work on stuff when I have the time...BUT...IF GRADS CAN DO IT, ANY 1st grader could do it....
That is true!
Pulled the trigger and it came in today. Looking forward to installing it. Thanks again for the feedback!
