Results 1 to 2 of 2
    Kalifornia
    Maxline or Rapid air
    Anyone use either of these systems in their garage?
    The Rapid air is only 3/8"ID, and the push in fittings I'm not too fond of. The Maxline is a little more expensive, but I can get it in 1/2" or 3/4".. looks like better fittings also.
    Senior Member Ziggy's Avatar
    Being from the automotive field I agree with you about the fittings. Always used automotive type but the others (push together type) work just fine. For less hose dragging hard plumb the garage with easy reach fittings. Schedule40 PVC works
    Depending on your compressor, size won't make a huge difference.
    From my POS T-mobile thingie
