Did you know a 20" inch + SS generator shaft will twist as much as 180d when you apply 300,000 HP to the input?
Those are, I'm assuming grade 5 or lower bolts. How tight are you torquing them to? Are they being stretched past their limit on install and then failing from the load maybe?
Did you know slamming a 500hp motor in gear at high rpm's will shear a 1 1/4" prop shaft clean in half like it was cut with a saw?
Lol good to know. I wonder how a MMW drive would mix 400lbs of dough.
Hey Cig, is it possible the bolts are loosening under load and then shearing?
Yes. Possible....I assume that's how they broke before. This time doesn't appear to be the case.
 Originally Posted by Cigalert
There is about 1/4" to the bottom. The bolts pictured were only in about an hour before snapping.
Sent from my DROID RAZR using Tapatalk
Stop going to Harbor Freight for your bolts......
 Originally Posted by Mateo
Stop going to Harbor Freight for your employees......
arreglado...mucho bueno
