Results 1 to 10 of 12
Thread: Baja Bug Wiring
    Baja Bug Wiring
    Almost done with a custom wiring job on a baja bug. Here are a couple of pictures.
    The old dash.
    All cut out
    New Livoursi gauges. Race rim, carbon fiber monster gauges. These things are huge.
    New dash mocked up and gauges installed
Size:  77.4 KBName:  104.jpg
    Pre wired the dash before installing it in the car.
Size:  68.7 KBName:  106.jpg
Size:  68.5 KBName:  107.jpg
Size:  63.3 KBName:  108.jpg
    If you cant read these gauges you shouldn't be driving. I know those of you that know me personally are wondering if I can see them.
    The front of the car is done. Just neet to wire the fuse panel and engine. The harness is all covered in wire net, with every connection and splice covered in heat shrink tube. No split loom and electrical tape here. It takes much longer to do it this way and if you forget a wire you have to start all over. It is totally worth it though. This wire harness will out last this car.
Size:  83.4 KBName:  110.jpg
Size:  66.7 KBName:  111.jpg
    That is insane! Great job!
    Jan 2013
    Love the bottle opener on the dash! 😁
    www.nickroseinsurance.com
    CA: 661.253.1131
    AZ: 928-669-2900
    Fuse panel is done
    Tail lights. Turn signals and brake lights. Although not DOT approved they should keep the cops away.
    More patience than I!
