View Poll Results: Vote for Hot Boat Decemeber
- Voters
- 46. You may not vote on this poll
HotBoat of the Month December 2013- SUBMIT HERE (26' and Under)
26' and under for this month folks. Please submit here.
My 04 21' Eliminator Daytona. My wife and flew down to eliminator to design the gel and discuss options. In May of 04, the boat was ready. I had Tom Papp's shop install the polished Aggressor Jet and Intake. The boat rides on a 02 Extreme trailer. I picked the boat up and got it home on Mother's day, 04. My wife claims the boat as her Mother's day present for that year. When I got the boat home, it had the interior, jet and motor plates installed.
I purchased a short block from a shop in Seattle. Dart block, Scat crank and h-beam rods, Je dished pistons neutral balanced. I also purchased the AFR 345 with 122cc CNC chambers from the same shop. compression ratio is about 8.25:1. The rest of the motor includes .630ish lift cam, all roller valve train with stud AFR girdles, HV oil pump, DBL roller timing chain, 2 piece timing cover, polished BDS 871 blower and intake, Lightning thru transom headers, Crane ignition, Demon 850 blower carbs, BG fuel pump and filter.
For tunes there is a Pioneer headunit, JL amps and 4 6.5" Infinity separate speakers and a 12" sub.
When I got the boat home, it had the interior, jet and motor plates installed. My oldest son and I wired the boat, assembled the long block and did the rest of the installs. We have only had minor issues with the boat since new. We are out at some lake (usually Saguaro in Phoenix) 3-4 weekends a month in the summer.
Hope you like the pictures.
Here are a couple of videos taken by a friend of my 04 21' Eliminator Daytona:
From the no wake zone on Saguaro to the main lake. Action starts at about 1:58
This one gets windy after the camera boat takes off. There isn't much to see after that.
Credit for the videos goes to Hot Boat member and my good friend, Cave. Hopefully you enjoyed the videos.
2013 Crackerbox
-Tom Patterson Hull
-Complete M&D Performance SBC w/ Buick heads pumping out insanse HP with a limitied 314CI restriction
-DG Stainless Exhaust
-We race around the country with the Lucas Oil Drag Racing Series
 Originally Posted by rivergames
2013 Crackerbox
-Tom Patterson Hull
Nice!!! Not everyone has one of these!
7 more spots left. Let's see your "Hotboats"!!!
Bump get your entries in....
