 Originally Posted by Carbon
The Optis really put a smile on your face at the gas pump. What warranty duration did you get Paul? Reason I ask is the lower unit is a weak link. I had one seize do to water intrusion. The gearcase does not have have enough room for heat expansion of the oil and pushes seals out. There are a couple of aftermarket things you can install when you go out of warranty if your concerned.
Mine had a 2 year warranty and it expired in March......I have the TorqueMaster lower unit which explains the gear ratio.....hopefully it's a little more stout.
I'll definitely hit you up if anything happens
Boat looks good 👍 can't beat outboards as far as fuel economy goes that's for sure
Ok, didn't realize you have Torque Master. I have not heard of any problems with them so you should be good. Your getting a lot out of that combination, kudos to whomever set it up. Not sure if you would benefit from a Sportmaster given that your already running 75+. I wish I was close, I would gladly let you expeiriment with my SM 1.62. It only takes 20 minutes to swap gearcases.
Where are you.....N. CA??
Tucson
Boat looks great Paul and nice video Dave.
Tucson
Well...........if you head up this way gimme a call and we'll go for a ride
For sure, and I'll bring the 1.62.
Here's a few props in my stable;
Got er trimmed up nice, movin' out pretty good.
Damn!!! That's a LOT of Props.
I've got a 24 and 26 4 Blade Cleaver.....looks kind of like the ones on the center row!!
