Starting your boat w/a hose on the trailer..???
Ok, for sound effects, PR's winning, Tis a close second with the blower surge and I can't get the one McRib posted to play.
Really? :(
A bucket is better but only because it actually forces the water pump to suck all the water. Force feeding it with a hose and muffs is fine. I always tape up the low water pickups if it has dual pickups so it can't suck air.
Where you have to be careful is two and three stage water pumps. They can generally suck more water than one garden hose can supply.
Hmm it wont play for me on mobile but open it in desktop mode if ur on ur phone and it will play.
It also helps if the particular shop you used in Havi has competent people that know which low water pickup to actually use. Because when they use the wrong one, the pump will fail shortly after you launch your boat. Then they will charge you to replace the pump, even though their tech said he used the wrong pickup But we won't use any names because this was a hypothetical story
hypothetical shit sucks...
I bet your hypothetical scenario cost real dollars.
