1990 Original Cheyenne 19
Im looking to move into something bigger and more big water friendly because i have moved to the Tampa Florida area. The boat is a 1990 Original Cheyenne 19' that i purchased in 2006 from Mike Tach. Mike Tach raced the boat and was very competitive. I replaced all the interior and wiring throughout the boat. Replace all the gauges with up dated Livorsi and Autometer ultra light gauges. I added level senders to the twin aluminum 11 gallon fuel tanks and also replaced the entire fuel system. The pump was built by Donnas Singleton and is a dominator. It has the larger impeller shaft and has a bronze straight A impeller with an inducer that was blue printed by George at ARS Marine. Im running a berkley droop snoot and a place diverter as well. The engine is a 565ci big block Chevrolet built with a boetie CNC block, Callies crank, Scat H beam rods, and coated JE pistons. It is a solid roller motor with a comp belt drive and msd crank trigger ignition. The cylinder heads are 24* ProToplines that are heavily ported along with a Super Victor Intake manifold and a Quick Fuel 1050 dominator carburetor. The engine was built and dynoed by Greg Stanfield (nhra proctock) and makes a true 810hp at 6200. The headers are Rewarder water injected headers. The boat comes on a trailer that is in great condition (just towed from Louisiana to Florida and also attended the meet on lake Kerr) I have many more photos and can provide any other information wanted. Feel free to call or text (701)520-2428 Lee
Nice boat.good luck with the sale
What's that aluminum thing on the inside left sponson?
Nice looking boat, what are you looking to get to replace it, were just 100+ miles South of you.
That would be the tow hook, mandatory by most sanctioning bodies should you choose to race it. A nice fail safe for any breakdown. FreeK OuT! =;->=
Thanks FreeK that would be the tow hook up front there.. and i don't have my mind set on anything exactly yet... Maybe a I/O cat that i can run a big inch LS in??
Thanks for the info. I've never noticed one of those at the races before.
nice boat, cant go wrong with red
