 Originally Posted by riverbound
For generators and stuff that might sit for a while. Use this in the gas that will sit.
When you put fresh gas in use upper cylinder lube.
can you take pic of the bottle?
Why you should put lucas upper cylinder lubricant
Both products have a completely different purpose and use. And can be used together as well based on application.
Ok I have a question for you guys. My TCM800 will run just fine on 91, so they say. I run 100LL. Have been for some time now. For me its cheap insurance. Since its LL, is there any benefit in running Lucas? if so, why? I think I'm around 280-300hrs on this thing and its still running like a top. I'm honestly afraid to change anything now.
heres what I know.... the lucas cushions the valve seats like lead...being a dragracer,... i'd pull the heads on your motor and see whats really going on...
on bad lifter will ruin your day......300 hrs on a blower motor??? have the valve covers been off
I haven't seen any benefit to treating the fuel when using av or race gas.
So whats you're saying is, since its running like a top. Tear it apart and see whats wrong? lol. I'm not touching it until it breaks
the idea is to see what little part will window the block and ruin everything...
the rockers and lifters on that motor gotta be just about done...
its probley best you don't ever touch it
See, you're assuming I want to save that little 509 block. What if I really want a 540 block and a 4L blower?? If I save the 509 I'd probably go back with it. But if she lets loose, what better reason to buy a 540? I don't think like a normal person lol
