	Thats cool!
					  Originally Posted by rivermobster   Next time you see the dolphins, slow way down and make a BIG wake.  They love to put on a show for you...
Thats Tom Brown taking pics off the back of OC's boat.    Attachment 15147
					Cat to Catalina Run pics
							We tried. Couldn't get a good wake going.
	I guess it's not that big if a deal then. Do you all run sea strainers, or is it that necessary for an occasional run in the salt water?
					  Originally Posted by Menace Marine   They have wash out stations at the ramp. I spray wd40 on my trailer wheels brakes and springs before we launch. I also spray the blower and flame arrester. They are exposed to the salt spray and it makes them easier to clean later. Once off the water I just run the boat on the hose for five minutes to flush the motor and inner cooler. Then a good thorough wash of the boat and trailer and your all done.
 Ideally the best thing would be to take the boat to a local lake the next day and dip it. This would more thoroughly flush the trailer. The salt ads a bit more work to the after boating routine but it is worth it every once in a while.
	I run one for the motor and one for the inner cooler. You would be fine without it. I have never had to clean mine out. Never even seen anything in it.
					  Originally Posted by 28eliminator   I guess it's not that big if a deal then. Do you all run sea strainers, or is it that necessary for an occasional run in the salt water?
	Thanks for the info...
					  Originally Posted by Menace Marine   I run one for the motor and one for the inner cooler. You would be fine without it. I have never had to clean mine out. Never even seen anything in it.
					Re: Cat to Catalina Run pics
	I don't let not having a sea strainer stop me from taking my boat in the ocean.  I would like to do this run next time.
 Sent from my DROID RAZR HD using Tapatalk 4
		You may not post new threadsYou may not post repliesYou may not post attachmentsYou may not edit your posts  Forum Rules
vBulletin Skin  By: PurevB.com |
