Battery cable splicer/distribution device
Basically what I am trying to accomplish is shortening the number of cables I have hooked up to my batteries.
Has anyone seen/heard of a device where I can run all my power to such thing and then from there, run 1 lrg battery cable and hook it up to my battery?
Hopefully this makes some kind of sense....
Racer
Run what ever you need positive to the starter this will hide alot of the connections and keep the battery terminals looking alot cleaner
I used a fuse block/ BusBbar. Check out some stuff here. http://www.iboats.com/Marine-Fuse-Bl...view_id.216615
blue sea has a nice 6 lug bus bar. lugs are big enough to facilitate a decent size ring connector
Blue Sea stuff is nice!
Yes it is. This is a recharging setup in the long long ago using blue sea stuff. Automatically tops off starting battery, once it's fully charged it switches to the back-up.
Attachment 10672
Thanks for the info, is this the part I am looking for?
http://www.bluesea.com/products/2126..._16in-18_Studs
Attachment 10672
Bakers shouldn't wire.
Lol ...
Re: Battery cable splicer/distribution device
You must be off your meds again.
Sent from my hemDROID
