Tapatalk test line 1
Tapatalk test line 2
Tapatalk test line 3
Tapatalk test line 4
End
Plus imagen
End
 Originally Posted by HB Vic
This is another Tapatalk year to see if it cuts off texts when i type too much
Check now please Vic
Image is for testing purposes only
Good morning thank you
Testing 1 2 3yyyhhhhhhhhggggffghhbvgggggggghghhgggbbbbbbbbbbbb bbbbbbbbbbbbb4
^^^ That passes.... the gas....
Plus imagen
End
I think I see part of the issue MG Benny cat, and it may not be tapatalk OR it may be...
The default number of returns/spaces in the format when the tapatalk post is made...
Previously when I quote someone there are only like one return/limited spaces after the body of the post BEFORE the HTML footer... Now I am seeing about four or five rows (blank lines) before the HTML footer in the tapatalk "quote"
Ok I am investigating that line.... it might be due to a 60 seconds autosave or a post character limit than can be causing the issue. I have just disabled the character limit and if that doesn
Well the character limit didn
