Results 11 to 20 of 21
  1. #11
    Rick King would have snatched that puppy up in a heartbeat!!!
    Looks good 2FF!
  2. #12
    I was able to get the gen going, flushed out the fuel system and she starts and runs like a champ,... got every thing working now, fridge, water heater, furnace, ac , and generator..
  3. #13
Size:  292.3 KBName:  25299963_1596141570422807_2784361140228595880_o.jpg
Size:  246.9 KBName:  25310991_1596142027089428_4299167852639779586_o.jpg
Size:  224.2 KBName:  25311014_1596142233756074_702237812673338901_o.jpg
Size:  189.8 KBName:  25311196_1596141343756163_2347818813040902862_o.jpg
Size:  287.4 KBName:  25311352_1596141067089524_8101358836545184464_o.jpg
Size:  260.2 KBName:  25351930_1596142303756067_4237403508027397684_o.jpg
Size:  174.8 KBName:  25352083_1596142387089392_3896243096263147942_o.jpg
Size:  187.2 KBName:  25358191_1596141777089453_1947267474822222795_o.jpg
Size:  187.9 KBName:  25358473_1596141217089509_4560664232079442452_o.jpg
Size:  228.9 KBName:  25394742_1596141930422771_7995184118060445714_o.jpg
Size:  209.0 KBName:  25394797_1596141103756187_5151799526957476241_o.jpg
Size:  255.4 KBName:  25394816_1596140977089533_1686698990667588034_o.jpg
  4. #14
    Definitely a handyman
  5. #15
    Wow looking forward to seeing the finished product.
  6. #16
    Awesome 2ff, you two make a great team!
  7. #17
    Sometimes you do things, and you know..."That anit gonna work"....and if it does ... not for long...lol..but I wanna make sure this RV is trouble free as can be..
    the heater...although it was working, and stayed working....it wasn't really fixed... squeeling motor was a sign that it was gonna fail again...so I ordered a new fan motor ..the last one went 24 yrs,.. so it was done...so a little set back on the completion date...but it's gonna be right...this rv is turning out to be pretty cool... gonna be a nice little tow rig,and a great dune rig... might as well do it right...
  8. #18
    Quote Originally Posted by CarolynandBob View Post
    LOL... so looking forward to that day...this rig has not leaked a drop of oil or anything,..I did notice a little antifreeze weeping out around the lower radiator hose ... hope it's not the water pump...but if it is, were gonna change out the hose's and if needed a water pump...the coach only has one battery for the living area... I noticed it was from 2012..might as well change it out ...everything propane seems to be working as it should...I have it plugged in at the house and keep everything running .. the converter keeps the battery at 13.5 volts..so that works as it should... but the battery drops volts quick when not plugged in..
    ebay has been great to get all the parts, most every part has been available...so, very soon to be done...
  9. #19
    Definitely an OLD handyman
    thanks, fixed it for you...lol,
  10. #20
    getting real close to done, got the new furnace motor in, now she works as it should,...changed out the head and tail lights to new ones, that and new porch light, sewer compartment door, 120v plug on the exterior..pretty much everything I could in bolt I replaced.... gonna be a nice little rig, oh and did a new magnaflow quiet exhaust,... the problem with the anti freeze leak was someone put a new water pump and never got the clamp thing enough,... so that's good to go now,..
    gonna do a new battery to day, and try to get new marker light lenses...I ordered summon maxium bags for the re, she has a little sway in the wind, and my son is gonna pull a box trailer with this rig.. so that will make it nice and safe...
