Results 1 to 3 of 3
    New Billet Top Rudder Bearing
    Top Rudder Bearing
    New billet Top Rudder Support Bearing, Made from 6061-T6 aluminum. Direct replacement for the painted steel unit in your boat now. Utilizes the same existing holes in your top rudder support brace, except these have 2x counter bored holes for 1/2" socket head cap screws for a clean look. Uses a 1" double sealed roller bearing.
    Same dimensions as the painted steel unit. Length: 5", Width: 2 3/4", Hole Spacing: 3 7/8", Height is 7/8".
    Price is $92.50
    Thanks, Phil
    Name:  Top Rudder Bearing.JPG
    Name:  Top Rudder Bearing Back.JPG
    D21's V-Drive Parts
    at
    1" Teflon Washer
    I made up some 1" thru hole Teflon washers, I've used these for years during rudder installations. I use these between any item that makes metal to metal contact. Used between the safety collars and the top rudder brace to control up and down movement in your rudder.
    O.D. is 1 1/2", I.D. is 1 1/32", Thickness is 1/8".
    Price $5.00 each
    Name:  teflon washer.JPG
    D21's V-Drive Parts
    at
    Just ordered one! Thanks Phil
