Results 1 to 7 of 7
    New Pro Whirlaway Housing
    Our Pro Whirlaway housing replaces your Whirlaway Spacer and Shift Box when running a clutch or transmission for a clean look while using standard whirlaway gears. Made from beautifully machined 6061-T6 aluminum that is approximately 5 3/4" long. Fits a standard 6 bolt pattern v-drive.
    Lemme know if ya need one.
    Thanks, Phil
    925-323-9093
    Name:  Pro Whirlaway Housing.JPG
    D21's V-Drive Parts
    at
    Nice stuff sir...
    SO to be clear, this eliminates neutral??? You are in gear full time with this conversion and you use the trans for neutral???
    Nice stuff sir...
    That is correct.
    D21's V-Drive Parts
    at
    That's nice!!
    Quote Originally Posted by Dimarco21 View Post
    That is correct.
    That is correct.
    GOod chewing the fat with you on the phone sir... Hope to meet up sometime soon...
    Thanks, Phil
    925-323-9093
    That's interesting Phil.. I'll have to see if the oldman is interested!!!
