Late 90’s Undercover Rear Engine Dragster
Late 90’s Undercover hard tail Dragster, 252” (21 ft), approx 1600 lbs
BBC 477ci Motor, Dart Pro 1 345 heads, Full Roller valve train, never sprayed, Alcohol w/ Holley.
Powerglide Trans w/6500 converter w/trans brake, Fully rebuilt at time of Rear end replacement.
Full Strange 9” Rear End w/Bickel housing replaced 4/2009 less than 20 run’s on it, 4.11 geared, new hard tail rear end is removable. 9” Pro Race spool, 28-35 spline axle package with 5/8” stud kit. Strange - PG 2 piece coupler.
MSD 7A12 Ignition,
Belt driven BLP Fuel Pump w/internal bypass, 2-way shutoff valve and BLP Fuel filter w/Stainless steel element added 4/2009,
Digital Delay/Crossover box
Good Year Rear tires/slicks 33.5x15.0-15 D6 DR SC replaced 5/2009, less than 30 passes.
Front Runner 22.0x2.5-17 tires replaced 3/10, less than 20 passes on them.
NEW Racepak Digital Dash WITH RECORDER
Body good, Chassis and Body recently painted
Cage style - large
Car is very consistent, fast and a BLAST to drive, Launches perfectly straight every time.
1.20 60 ft’s, has reached 1.13’s with lighter driver.
5.20 et @ 138mph 1/8, 8.40 et @ 163mph 1/4.
NHRA Chassis certification for 7.5
Price 26K Make Offer
asking price and location Thanks Wild Bill Sparks Nv.
Seller is still trying to decide on the asking price but I think he is leaning in the mid 20's neighborhood. Location is 30 minutes west of St Louis and the truck terminal is St Louis metro. THis particular truck line was/is a contact that was used as a SECURED contract hauler for Boeing aircraft parts from STL Mo. to LB Ca..
He has a friend/contact that does long haul transport and is already prepared to load/haul to wherever, the cost of shipping would be factored into the final price.
Obviously someone could set up their own deal for transport if the buyer desires.
TY for the interest Wild Bill, this thing really is turn key and the glide/rear end is fresh. I believe that there is well over 8k invested in the rear end and the work that was done at Jerry Bickle's shop when the new rear end was built/purchased. The glide was freshened at that time.
This type of rail will hang right there (without the added hassle OR adjustments/parts coming loose) with a soft tail/four link set up and this rail can go much much faster than this is currently set up for.
Bring us a SERIOUS offer around 20K and see what happens... The driveline is worth more than this...
Springtime bump
