79 CVX 20 jet restored videos and specs
Runs 72 mph GPS @4900 rpm AA impeller
460 BBF Parts and machining list
Harmon long bolt logs port matched and outlets enlarged from 2 7/8” to 3.5” with new 4” tips
Performer RPM Intake port matchedXM278H K34-241-5 CompCams Kit http://www.compcams.com/Cam_Specs/Ca...csid=1002&sb=2
Drilled block oil drain back holes from 1/2" to 9/16" and added one.
1 pair of C8VEE heads CNC ported by Red Man
One set of Ferrea 1.76 exh valves
One set of Ferrea 2.19 intake valves
One set of exhaust seats
ARP Guide plates
ARP 7/16 studs
Roller rockers BB FORD PROCOMP T6 ALUMINUM ROLLER ROCKERS 351C 429 460 Smith Bros, Restricted 3/8” push rods)
Ford Racing Tall valve covers
VC cover stud kit ARP 400-7614 stainless 12 point
Arp intake bolts
Stock crank 10/10
All bearings Clevite
Armondo 10 Qt. oil pan
Mellings HV oil pump
ARP HP oil pump shaft
New dizzy gear and pin
ARP rod studs with truck rods
Ford truck rods D6VE-AA
sealed power hyperutectic .040 over pistons 22cc
Block bored .040 over stock /decked .029"
Oil drain back holes added or enlarged
Dizzy gear oil modification
ARP HP oil pump drive shaft
New Holley 850CFM double pump w/ Non-metallic Carb spacer w/ studs
"Marine" engine gasket set*from Jet boat Performance (does not seem different from stock except for repackaging by marine parts company).
Timing cover gasket set w/ seal
new headbolts and ARP main studs
Berkeley 12JE pump
I rebuilt it completely with new American Turbine aluminum AA impeller set at ..022”
turns AA impeller 4900 RPM at 72 mph gps
New Teleflex gauges 80 mph and 7000 rpm tach
New instrument panel for larger guages
http://www.overtons.com/modperl/prod...te&merchID=400
Place diverter with push button control .
Thanks for sharing! And welcome to the site BTW.
Pretty cool! Looks like a fun boat.
Back and forth
Sent from my SCH-I435 using Tapatalk
Great video and even better first post! Welcome!
Another mysterious missing post?
I'm not seeing any missing posts here? OP edited his og post today if that's what you're talking about?
OH. Like clean off the thread? TODAY?? I don't remember seeing anything YESTERDAY when I posted. Who was the OP. I take there was a video at one time. Kind of a use thread now.
Thanks for bringing attention to this.
He edited his original post that included 'links' so it was automatically moderated again. Because he has less than 5 posts and posted a link it gets auto moderated until approved because of the anti-spamware.
All is well now.
All is well now.
I was pretty sure admin was up to their typical bullshit.
