Page 27 of 43 FirstFirst ... 17252627282937 ... LastLast
Results 261 to 270 of 421
  1. #261
    I used a USPS mid size flat rate box weighing about 8# to send some camera parts to AZ for 65.00. You could ship a bunch of shirts in one box for this.
  2. #262
    Quote Originally Posted by Lifes Rough View Post
    Anyone have an economic way to send these to Australia, We have 4 inquiries and fed-ex looks to be around 125.00 a shirt to get them there
    Tell Dean he has to wait until Long Beach to get them...
  3. #263
    K-711 making a comeback
    Found our oiling problem! 😣
  4. #264
    Oh that doesn't look right at all
  5. #265
    Jan 2013
    Yea, I agree ^^^ 😕
    www.nickroseinsurance.com
    CA: 661.253.1131
    AZ: 928-669-2900
  6. #266
    San Pedro Ca
    Found our oiling problem! ��
    what caused the filter to collapse ? and what brand of element is that?
  7. #267
    It's some billet deal with a stainless element, my dad has run the same filter on his blown cruiser for years and has never had any issues
  8. #268
    San Pedro Ca
    ugly is all i can say
  9. #269
    Its a Professional Products Stainless Steel Mesh filter.
    Any number of things 3.5" or 4.25" filter instead of the 4.5"
    10 micron element instead of the 45 micron
    Heavy straight weight oil on a cool Parker morning fire off and no bypass in the filter or block
    All of the above.
    When that happens, it happens in less than a blink of the eye. Like a pin on a balloon
    Zero pressure in the block(and inside the filter element) in rush of molasses thick oil on the outside of the element trying to get thru the filter. The filter is designed to flow oil thru the element with about 8lbs difference between the pressure coming in, and the pressure in the block.
    Make that pressure 100lbs and zero, and this can be the result.
    The easier it is for the oil to pass thru the filter, lighter oil or larger micron, the less likely this happens.
    ANY filter can do it. Cold morning, molasses in the oil pan, no bypass, and jiggy with the throttle is all it takes.
    A blown alky deal starting off a squirt bottle can be hard to control the starting Rs. .001 second is all it takes.Name:  fram filter.jpg
Size:  29.0 KBName:  collapsed filter 2.jpg
Size:  27.0 KBName:  Crushed_Filter3.jpg
  10. #270
    Jan 2014
    Pokunkville
    My guess is Jiggy with the throttle !!!!!!!!!!!!!! LOL
