Those sure are pretty Eddie! Do they manufacture over hub props and have you tried an over hub?
Kevin could ask those answer those questions..I know he make a varity of props...but I'm pretty sure he can build different hub "setups" I'm thinking I 'm wanting a solid inner hub next time and have Kevin do the machine work
Like this? These are the epitome of badass props.
One question. What is the advantage to having a straight edge on the trailing side of the prop blade? Nice props BTW.
That's some good lookin hardware Eddie!! What kind of numbers are you looking for?
Where are they located?
And I thought Westernaero had a machine shop, wtf is a bitching shop?
Idk the answer to your question Grads, but the straight trailing edge is synonymous with cleavers and known as "rake". My guess is it pushes more water than a rounded ear.
Grads, I really can't answer that..BUT..you more than welcome to come down and test and see How the props work...we know some tweeking will be involved...as For numbers? we ran a "labbed" 34 when first took it out..we ran 119...the motor is no where near it's rev limiter...So with this new drive and new props we will do some testing...Dustin has a stock 36 we can try...BTW...the 34 we ran was not a "perfect prop"..Auggie has it right now to work it over...for some reason the 34 4 blade merc prop was not a good choice for the Daytona...32 and 36 seem to be the props to run with our hp setup
