Results 11 to 20 of 27
Thread: Blown engines
  1. #11
    Casale sells them without the welding BS
  2. #12
    Clovis, Ca.
    We modified this lower cost one. Broached extra 1/4" keyway, machined register, drilled and tapped ce19 pattern. Then I decided to use a River Rat pump and could'nt run this damper lol.Name:  ImageUploadedByTapatalk1395435737.862867.jpg
  3. #13
    Thats crazy, I've never seen one like that
  4. #14
    Clovis, Ca.
    That first one I posted looked a little sketchy to me which is why I went with something different. I was told that a lot of people used that setup year's ago.
  5. #15
    Casale sold them, may still have some, that didn't have the welded mumbo jumbo..
  6. #16
    I use the ATI balancer on every engine I do and have since about 1992 or so ?
    The make the hubs for me. I bought one of the "Jesel" blower units, looked it over,
    called them asked if they would make the hub to fit a gear drive ( timing chain cover ) ?
    Yep, send us a drawing. Bam , got the hubs.
    Maybe that is how I get away with the stock cranks in the K engines ? ( 1400 hp )
    But, we also made a crank support. I wanted that because I drive the dry sump pump
    off a 8mm belt between the damper (GN7) and the gear drive seal adapter ( RCD ).
    The crank support shaft id double keyed into the ATI hub. We built the first one in 1995.
    The K engine has had the same ATI unit one it, since 2003.
    The backup K engine has had it since 2010.
    http://tribalthunderracing.com/photos/crsp
    If somebody wants more pics , I can take what ever you need.
  7. #17
    Clovis, Ca.
    Quote Originally Posted by wizbang View Post
    Hey Hotdog! Got any pics of that ATI?
  8. #18
  9. #19
    http://www.atiracing.com/products/da...hubs/index.htm
    http://www.jegs.com/i/ATI/085/918871E/10002/-1
    The ATI website pic shows a couple Ford models with the belt drive area
    Welcome to www.hotboat.com!
  10. #20
    Thank you ,,,, MRS K-034 chewed my ass for not joining !
